6 hours ago, Stere said:
Whats different  about the nordfest one- the spiked plate on top?
Just had a google theres a couple of other top plate design ideas about in UK
RAMJACK-clark-ram-jack-hydraulic-tree-li
Clark forest one
Also a retrofit kit
WWW.GRUBE.EU
Upgrade your 30t Weber hydraulic feller lever with the Nordforest Aluminium Felling Lever Pressure Plate. Ensuring...
The Nordforest one, once its bedded in will not slip.
I've not tried the Clark one, so i can't comment ,  but i think that they are similar in design .
The Nordforest one you have looks far more better than the Clark one. Look forward to seeing more videos of Welsh(?) forestry
Time to film is my biggest issue.
14 hours ago, slack ma girdle said:
Thank for that,  thats a bit of bold forward thinking from FISA
No bother, it is somewhat surprising to see FISA getting to grips with reality!
12 hours ago, slack ma girdle said:
Have you come across Calum Duffy, he has loads of different jacks, it would be worth chatting to him.
And no doubt @Spruce Pirate has had a little experience with them.
I've mostly used a 20t Clarke bottle jack with adaptor plate, but I have used the Treemans a couple of times.  The Treemans is definitely a nicer product, the spreader plate being attached is great but the biggest difference seems to be the amount the ram advances with each pump of the handle which on the Treemans is a lot compared to an ordinary bottle jack.  Unfortunately the price is almost prohibitive, certainly hard to justify against an off the shelf bottle jack and a plate.
I'm pretty sure Calum has the Treemans, the Clarke Forest and a Borntrager jack so he'd be the man to ask how they compare.
  • 3 months later...
Its been a while, but you lucky people can have the pleasure of another gripping video from the Hairy Fool. You might have to pause it half way through,because it might be just too exciting...............
Enjoy
#Dullasditchwater
  • Like 6
  • 4 months later...
