On 21/11/2019 at 08:27, woody paul said:
I do not think it can  be classed as tractor to much modified, we're as valtra used standard tractor and got 70mph out off it.
I take your point but the Valtra was hardly standard as it looks like they had a direct drive from the diff to the rear wheel, to get the gearing up, and removed the front wheel drive  for similar reason.
I guess this is why 130kph was  as fast as they could get with a 40kph gearbox (assuming a normal reduction in the trumpet housing of around 4:1). Mind 130kph with those tyres and no suspension could get a bit exciting.
On 21/11/2019 at 01:14, difflock said:
WWW.EQUIPMENTWORLD.COM
Apparently setting one world record in 2019 wasn’t enough for the folks at JCB. Following record-breaking runs in June that made the JCB Fastrac the world’s fastest tractor, the team...
They did not mention if she was running on a "drap o the Cherry", or praper clear Diesel, most odd?
Not impressed. 16 year old lads  are doing close to that... with trailers, round here. :P
Edited by Gary Prentice
