Hydraulic power pack
woody paul
  On 20/10/2019 at 14:45, Svts said:
That's a tidy job. Just looking into doing this myself to save tying up a tractor. Any chance you could give details of the engine size etc?  Looking at a 24hp Honda to drive it so hopefully enough flow for a decent ram speed.
Expand
Engine is a lombardini 20hp diesel a pair of 11cc hydraulic pumps with 1 going throu a unloading valve set at 140 bar so when it gets to much that pump drops out and the other do's the rest same as a two stage pump.
Rev set at about 2000 rpm giving 40lpm.
I did also to free up tractor and so I don't have take tractor on job to split timber for customers.
Not a cheap project but got what I wanted in the end.
Edited by woody paul
Expand
Thanks for that. Pretty similar to what I was hoping to do. Agree its not a cheap solution once all the bits are sourced. But should be a lot more flexible to use and not run the tractor hours up unnecessarily. Thanks for getting back that's very helpful.
Read more
