441 advice
jamesmerriman7
Still under warranty, take it back and get them to see what the saw is up to. The software should tell the tech what the fuel is doing and that may help diagnosing the issues.
Sorry, I forgot, just run it on Motormix, it sorts out all poor running machines apparently9_9
Are you sure your not going through the male menopause?
Been quite tetchy in recent posts.
  • Haha 3
I have a few family issues and am busy, it is hot plus I don't get enough me time so yup, some comments are just worth a bit of harsh sarcasm and I know.....it is the lowest form of humour but can fresh fuel fix low compression, dodgy sparkplug, rattly bottom end, blocked gauze strainer, split fuel line etc........9_9 Another guy said he would always strip and inspect rather than just returning a bit of kit with fresh fuel and running after it was handed over not running.....spot on in my book! Who wants a field failure and your customer looking a right twat in front of their customer.
The loose bar, sure I am glad the guy fixed it but the route cause was surely the bar stud flange stopping the cover clamping the bar due to the spacer bar plate being missing and the bar being slightly thinner.
The fella that measured everything was spot on the owner said the flange was well below the thickness of the bar....really....can't have been can it.......Grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
There are quite a few guys on here I do respect who really know their stuff in regards to repair and a few that ....think they do. I am still learning, just happens less and less the more you do!
Male Menopause ......quite possibly! Normal service will resume!
