Best narrow access stump grinder in 2019?
benedmonds
I have a HB20 and can see it outlasting me.
The new ones can just about go through a 25 inch gap when you take of  the outer wheel.
Could you not recondition the one you have.
The only downside I find is it is a heavy machine and you do feel it at the end of the day.
After speaking with Dean at bandit we have some different options.
Trade in our  44hp 2150 for a 38hp zt1844.
The zt is similar width as hb20 but apparently comparable in grinding ability to our big 2150..?
Any opinions on the zt1844
Edited by benedmonds
Speak to Gray Git on here and Josharb, there s loads of others as well
First thought is if you have a pedestrian grinder for tight access, a ZT might not be suitable.
The ZT is, or might be as narrow as the HB, but its long too. 2.7m if i remember correctly. The length might make tight access turns awkward? Ive no idea what you're "tight access" look like, but narrow and sharp turn will be tricky with the ZT
A pedestrian style wheeled machine will also be kinder on lawns when positioning in small gardens. Tracks do scrub up grass.
Didn't Jo-beau come out with a pedestrian grinder with hydraulic powered swing? best of both worlds?
