how often do you change a sprocket
48 members have voted
  1. 1. how often do you change a sprocket
how often should you replace a sprocket on your saws if you know the answer well done if not shame on you
without looking it up give us your answers
  • Replies 38
this is dodgy. if your using a saw up a tree the chain will last alot longer then on the ground as theres less chance of it hitting the ground, stones, nails... so the top handles sprocket would get alot more wear for 3 chains then a ground saw.
