Advice needed for mower to buy
Robdog78
Dear all,
I am looking for some advice on buying a lawnmower mower for domestic use. I have a two acre meadow that I would like to mow occasionally (2-3 times per year). The main challenge is that the field is sloped (approx 30-40 degrees on at least 25% of field including access track and then less sloped on the rest). As I live in Scotland and the grass would be quite long I guess that 4wd or AWD etc would be needed. I would like to spend no more than £5k but am unsure whether a ride on or walk behind would be the best option. A mulch option would be preferable with side discharge (plus collector if ride on). I had been looking at the Lawnflite WCM84E wide cut mower (although cannot find any reviews on this) which seems like a cheap option for such little use but I also like the idea of a ride on with grass collection (eg Cub cadet xt3 range) to save my legs.  Any thoughts appreciated.
Many thanks,
Robin
15 hours ago, daveatdave said:
if you are only cutting it 2/3 times each season it could be 2 ft. high when you cut it, get a local farmer in to cut it if there is tractor access it will be a lot cheaper than spending 5k on a mower that will struggle to do the job
What he said. You could cut it for at least 10 years that way without the agro of fuel and maintenence
18 hours ago, Robdog78 said:
Dear all,
Many thanks,
Robin
"Hire" a cow/sheep/horse/lama/geese/rabbits, whatever is available locally, most animal owners would be only too happy at the thought of free grazing?
Edited by difflock
