Took a 281 in as a trade in against a 562 last weekend and I’ve a mate looking for a milling saw, he was using his bosses 3120 but it’s time to get his own saw. Would the 281 pull his 36” bar? It’s not long term but something to keep him going until he can afford a 3120/880 of his own.
Probably pushing it, milling isn't my thing but perhaps a skip/semi skip chain would help. The 281 should have a good amount of torque grunt which is positive and they do tune up well.
The 281 doesn't share the same bar mount as a 3120....does that scupper the idea?
7 minutes ago, adw said:
281 does have the same bar mount as 3120
I thought that but was to frightened to say ?
I think , in this case it is actually 81cc . 52mm bore , 38mm stroke . Whereas the 288 is 87cc .
Edited by Stubby
Yes.
But I wouldn't mill over 30" with it.
[emoji106]
Bar mount is D009.  5.7HP . Ignition timing is fixed so you got to be bold when you yank it over !
Edited by Stubby
