Won't you go to prison for using that on the ground ? [emoji16]
The house is surrounded by police as we speak!!
Nice!
Where did you get mod from?
Thanks bud. I brazed it myself. I stared off with a smaller hole but after a while went to that size.
I drilled the zorst on mine and found the entire side of the saw was getting so hot you couldn't touch it, even the chain brake casing. Bought a new zorst and all was fine again. Not sure what I did wrong
Did you richen the h screw after drilling?
Yes, well I say that. I just had a little play till it all sounded/ran nicely and I had to do the same when I put anew zorst back on
Did you notice it running any better apart from it all getting good and hot? Maybe its needs the little bit of pipe to shoot the hot fumes away?
