Just now, topchippyles said:
When you get an a thumb nail play in the band just re band it. 200 metres of banding is peanuts to buy
Aye, thats true. :) That is of course if you can assess it still. :D
18 minutes ago, Macpherson said:
I tried ratchet straps but now just use loops of rope tightened with a twisting stick so easily adjusted as the wood shrinks ?
To much play even in a tightened ratchet straps
Edited by topchippyles
Well setup your stacking system to allow for it. Not rocket science ? Opened up a pack of ash strings on monday which have been drying for 18 months inside. Re tightened about 8 months ago about not a blemish on a single 4.8 metre length string on a batch of 6. Moisture was at 12% on the meter
what would you recommend i do with these slabs of beech, i've just got 3, 5 ton ratchet straps on them, mega mega tight
they will be outside a little while before they go in the kiln
then a sheet of celotex over the top
is there more i should be doing to make sure they don't move, they'll be for table tops so!!
thanks
On 24/03/2020 at 22:41, astra25 said:
I did one cut with my chainsaw mill lol haven't used it for quite a few years now since I made a bandmill, I made it when I got a tig welder and wanted to make something to practice.
20200323_102643.thumb.jpg.4744a02bc06f5b3d9609994b5124169b.jpg20200323_113538.thumb.jpg.f279f8a8b571f42bfd592c67e0c44e0e.jpg20200323_115243.thumb.jpg.6085fb80680b97937d9052ebb4cdb93f.jpg20200323_115836.thumb.jpg.77d0ec7dc998698fc329a9fd6b52c03e.jpg
Nice little mill there. I guess you can only slab up fairly small stuff with that?
On 29/03/2020 at 13:33, Forest2Furniture said:
I've got me some Larch to mill during the self isolating period!
That'll keep you out of trouble for a bit. Have you had time to progress with the milling?
2 days for me that would be. 1 of my regular saw guys who is well up to speed cutting on a woodlands HM 130 But i have an excavator for loading which takes the heavy work out of it. 2 days x 2 men but i wound maximise each log
7 hours ago, Forest2Furniture said:
I've started the Larch!
I know it's not particularly exciting but one does what one can in these restricted times!
Just saw this. Nice. Looking good!
