What use do you have in mind for the alder, if you don't mind my asking? I have a couple of fair-sized ones in my inbox.
To be fair, I felled it as it was hanging out along a path, so decided it would be nice to try milling it. So long story short. No plan yet.
And you?
No plans, but I'm very interested because oddly we have a very healthy 1 acre plantation of it - only ten years old but going like a train. It was planted quite widely here in Ireland recently (as well as thriving on river banks and hedgerows and so on). It seems that its principal virtue is that it's easy to work and fairly light in weight. It's neither strong nor durable, which is why it typically has such a bad reputation.
I'd love to find a use for it in our house restoration we're having a go at - it seems like joinery is the best hope - it's too soft to use as floorboards. Come to think of it our architect has just specified vertical tongue and groove (very tight so you can hardly see the lines) for the interior walls instead of plasterboard, and it might work very well for that if we could get enough of it together.
Because there's quite a lot of it in a similar stage as ours, there is some work going on to try and find markets for it here -
32 minutes ago, Khriss said:
Nicely done and no fencing wire 🙂 K
Thank you Khriss - I think I've got to go back in fiddle with my wheels, for the blade seems to have developed an upward slop - as it comes out of the wood I can no longer just wheel it back, but have to raise the head - that only mean that the blade is cutting at an angle I think. I've got one more similar to do, which will probably give me just not quite enough for the staircase. Ha!
And you?
Interestingly, though it's soft, it's a little less soft than pine, which of course is used for floorboards all the time - here's a picture of a very sexy alder floor
Hallway and Medium Hardwood Floor Alder has been used for both custom doors and wide plank flooring of this home in Genesee, Colorado. Select alder was chosen for its closed grain and its natural beauty—qualities which are highlighted by the factory pre-finish color which was chosen.
alder-has-been-used-for-both-custom-doors-and-wide-plank-flooring-of-this-home-in-genesee-colorado-select-alder-was-chosen-for-its-closed-grain-and-its-natural-beautyqualities-which-are-highlighted-by-the-factory-pre-finish-color-which-was-chosen-genesee-.png
That’s very nice indeed. Well I’ve got bits and bobs around. Maybe one day some alder floor boards.
apparently one of the reasons woodworkers like it is that it stains very well - so that floor is faked up a bit to look
likesomething more expensive, but hey!
That's interesting, I've got a few acres of alder about the same size as the logs in your link. I've milled a little and it seems fairly stable.
I'm planning on using some for floor boards and some for shelving. Offcuts are nice to cook over.
I have a bit of a mix, so from about 6" to 12". I only have a small chainsaw mill so I hope to mill into 3" planks and then slice them up using a 3" circular saw to give me 2.5" planks once planed.
I've mentioned before that my OH has a spinning wheel mostly made from Alder so I expect alder to be fairly stable once seasoned.
