Generally I turn down resaw jobs.
Nearly every one has gone wrong.
Nails,bolts etc.
Or just wood so hard it dulls the chain teeth before finishing the cut on big stuff.
Got one in two weeks to resaw some big elm slabs.
Taking lots of spare sharp chains.
[emoji106]
Was asked to resize some old dry Elm for a mate [emoji15][emoji15]. I’m no expert on Timber characteristics as it ages but certainly did not expect it to be so hard, it was destroying ripper 37 blades like they were made of plastic. One of those favours I had to finish but definitely an eye opener and a wood to avoid in the future, unless there is a specific blade,tooth,angle etc for it ??.
Logosol do a carbide tipped bandsaw blade.
No sharpening, just use it til it dies.
Will cut through nearly anything apparently.
[emoji106]
Have you ever tried dribbling water from a garden hose through the kerf kind of like treating the wood as if it were metal you were cutting very dry stuff.....I mean you would never try to cut metal on a machine without lubricant / coolant.
Normally when you cut wood with a saw it already contains about 30% h2o.
It may of course not always be practical but from my engineering background to me at least it's logical, I recon that when I've tried this the chain kept sharp for longer, although waterproofs are required.
TCT blades are easily and cheaply sharpened btw.....Cheers.
[emoji106]
I think they are Bacho? Could be worth looking on their site as Logosol will most likely stock Logosol Sizes?
Thinking about hard dry wood I’m planning on re-sawing dry Ash Slabs. [emoji33] Guess I need to look into Carbide blades or some frozen timber ones.
I live in Yorkshire.
Everything is wet all the time.
[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️[emoji299]️
???[emoji106]
On 06/11/2020 at 11:40, Johnsond said:
Was asked to resize some old dry Elm for a mate ??. I’m no expert on Timber characteristics as it ages but certainly did not expect it to be so hard, it was destroying ripper 37 blades like they were made of plastic. One of those favours I had to finish but definitely an eye opener and a wood to avoid in the future, unless there is a specific blade,tooth,angle etc for it ??.
 I worked for a guy who used to re saw large volumes of reclaimed timber from Dibnah’s mill demolitions, mostly Pitch Pine and Douglas, but we milled just about everything else also.
The bandsaw was a Forestor with 4” blades. It had a container filled with diluted diesel and a swab that coated the blade the entire time, it certainly did improve the life of the blade and improved the cut whilst in operation.
Dry Elm is like concrete.
Just now, Forest2Furniture said:
I milled some Burr Oak for the first time last week, very pleased with the results.
7 pairs of book-matched boards
Damn! I think they’re the best looking slabs I’ve seen on here to date! Bet they bring in a pretty penny.
Jeez that's beautiful timber.  Can't work out how it went - was that an ancient stub, or is it a cross-section or what?  Looks like it was the stub of a branch that withered away at the end. :confused1:
It's from the base of a trunk about 5' in length and 28" diameter at it's widest
