47 minutes ago, wyk said:
You'd think the photo of me from a hospital bed would be enough...
You would, but it's not, we want vid!
7 minutes ago, Stubby said:
How about the " soft Dutchman " with a tapered hinge ? :D
Or the midnight stealth step-cut ?
Is it just me or was that a load of bollocks???
Lower hinge had no effect, tree fell in direction of gob cut.
Might of worked with a partial humbolt?
[emoji52][emoji52][emoji52]
No one wants to see a pro forester in hospital* an there is a simple method fr heavy leaner ( used a jcb loader as a guy rope anchor once ) an directed fells- I always go fr safer option. That cut looked bit fraught with possibilities :/ k
*( but have a go home owners is hilarious !)
'Bahhh ! Humbolt ! :santaclaus: K
Edited by Khriss
Hilarity
You put the face cut directed towards where you want it to fall. It fell about 90* from the lean, which was the purpose of a sizwheel. The extra hinge on that side slowly breaks away from the stump, causing the tree to swing. Assuming it isn't a horse chestnut*cough*
I saw a video where the cutter put part of the gob back in the cut and achieved similar results with a lot less messing about and the stump was cut a lot nearer the ground :D
That's a hard dutchman. You can get away with it if the tree has wood that won't give easily like in some firs. I've used it often in a fir. But it won't get you 90* from the lean unless you also work the hinge as well. On a chestnut, I can see it breaking the hinge quickly, or causing a barber chair.
Edited by wyk
