1 minute ago, aspenarb said:
Just fit a flick switch on the trailer that switches the fogs over to reverse lights ( blue wire) . I have done this before and fitted led reversing lights down both sides and the back of the trailer
Bob
Is what I am thinking but with a remote so everything can be water tight on trailer.
Beat me to it [emoji106] or you could piggy back off your original feed somewhere using a weatherproof plug.
11 minutes ago, Ratman said:
Beat me to it emoji106.png or you could piggy back off your original feed somewhere using a weatherproof plug.
This^^, just splice into the original wiring.
26 minutes ago, woody paul said:
Not got a spare terminal in plug so how do you get power to lights.??
you put both brake lights in to one to free up a spare terminal in plug and then wire that in to reverse lamps, got totally pissed off with hazzard lighs fog lights and brake light trick no where near sufficent for what i needed so fitted a 9 LED light wired in to reverse lights works a treat and you can see what your doing very well, 2 holes to drill and a bit of wiring about an hour to fit,
Got it but you must mean put both tail lights in to same as only 1 brake wire. But i do not want to rewire all truck.
Edited by woody paul
Do the job properly & fit 13 pin plugs & sockets to them all.
No dont bodge it so its not compatible with any other vehicle or trailer.
Do the job right & fit 13 pin plugs & sockets.
yes you could mine is on brake lights i think but both my trucks and trailers are wired as i want them, lights wont work on any other car/van/truck hence it stops people asking can i borrow your trailer,,,
If you get a fully pined sockets & plugs there are some spare terminals so as well as standard reverse lights for use on the road you could wire in rear flood lights too.
