Can anyone help.
The cable seems to be sticking on full and not returning when I let go of the throttle.
I have taken apart and looked inside the handle and also the carb and all springs seem to be working.
The cable does not want to return on its own and I can only push it back from the carb end.
Do I need to replace the whole cable or is there something I have missed?
Thanks in advance.
try putting some light oil into the cable housing and work it in do not use wd40 as this will degrade the sheathing on the cable
sorry for the underlining I cannot get rid of it
On 03/11/2018 at 07:14, treevolution said:
Thanks.
Will try that first.
Would you recommend any brand of oil.
More than likely there is a pulled thread on the inner somewhere and it's binding. Try the oil but I suspect the whole thing will need to be changed.
I will try the oil and if I don't have any luck will look at changing the cable.
Thanks for the help.
I ve the same problem with mine. Oil did not cure it, i had to replace, somebody said the oil actually makes the inner sheath swell and cause the problem?? not sure if thats right or not.
  • 4 weeks later...
Just to close this one off, the sheath had sheared in two and had then chafed the cable. A new cable and a bit of non related TLC got it going nicely. The sheath is steel and plastic, the metal won't change shape with oiling!
