Tothetree's!
Iveco 35c12 low ground clearance
Just got it, 10 plate double cab tipper, shame the fuel tank and exhaust box scrape on the pavement when I reverse down my  sloping drive.. anyone solved the same problem?
Share this post
Link to post
just logged onto arbtalk to search the same (or similar) question.
doesn't look like anyone has a definitive answer.
I was looking at the van earlier thinking of taller tyres but not sure how that would affect the vehicle.
Share this post
Link to post
I made a (very basic) skid plate under the tank out of an old road sign which helped. Also had HD springs in the rear and slightly taller tyres, but just need to be aware! No easy fix though.
Share this post
Link to post
Been through this years ago... ripped bottom of 2 tanks on a crew cab I owned.
had enough.
Got a fuel tank of an ldv convoy tipper. One with a nozzle and cap with a key. Also got the brackets with it. Thinknit was maybe 80.00 ish. That bolted onto the chassis easy and was well up out of the way. From recollection i could also fuel it up without having to tip the body up slightly also. Rewired into the fuel sender on the ldv tank and guage worked too :)
Theres your fix boys. Was spot on then
Share this post
Link to post
Glad that worked for you swinny my tipper pack is on the passenger side..
monkey - did you get much extra clearance with bigger springs?
Think going up a tyre size 195.65.16 to 195.70.16 will get me the 10mm I need but all 6 are nearly new
Share this post
Link to post
Can you not move power pack to the other side? Its only one hose and a few wires. Or mount tank at other side and extend pipes and wires to the sender
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
