Just now, Steve Bullman said:
Yep, always drop a file size.  More like the last quarter than the half way though.
I been known to drop to as low as an 020  file on a 3/8 chain before
Done this also . Tight wads we are ! not binning this chain till at least 5 cutters break off ! ?
Been doing that for years if I happen to have the slightly smaller file but its not critical . Certainly not " advanced " ! [emoji3]
We can get onto "very advanced"
(Hooking,square cut etc)
Later mate.[emoji12]
If stihlGB technical have to contact head office in Germany for advice, I'd say it's advanced for most.
[emoji848][emoji12][emoji106]
No . Stihl GB are just young . ? Don't forget if you square file a full chiz its done from the outside in rather than from the inside out as pr round ground full chiz :P
Edited by Stubby
Also when you get to the dropping down a file size stage its worth taking the gullets out as well with an 020 size file .
Whys that please stubby?
I’ve been doing it inside out with good results
Ok . If that works for you its all good . To be honest I have not done a lot of it ( despite what people may think ) . I wanted to try it and when I researched it that was the recommended way .
1 minute ago, Wonky said:
Here's somthing else from a Carlton manual I have.
just chucking it out, as we’re talking dropping file sizes, what about depth gauges.
That is for the same reason the top plate drops down as you file back down the slope  sooo the rakers need to be 1/5th of the file diameter below the top plate so it will be more as the top plate becomes lower .
