1 minute ago, Puffingbilly413 said:
Andy - I was really just pointing out that your comment ' I’ve been through the book extensively, there is simply nothing there promoting the burning or drying of softwood' doesn't wash.  There are many references to the drying of wood in general and to the burning of softwood in particular.  Pine, of course, is just one example of softwood - Mytting also covers spruce.
There is nothing, let alone lots and lots on drying softwood is there? You mentioned pages 60 and 61. It does not really remote the burning of softwood does it? Its hardly lots and lots of Spot-on info on burning soft wood. Kindling and Kitchen Wood and if you want more light hardly constitutes promoting does it? Then the two pages goes on to say that you'll have to sweep everything out that much more regularly.
You may thing that does not wash but I sure think it does.
True - drying mostly just covers 'wood' as there is no difference in the process is there.  Pine and spruce drying is referred to, albeit briefly, on p47.
He also mentions combining softwoods with hardwoods in the fire to help prolong burn times on p48.  People's enjoyment of theg crackle of conifer woods in their stoves is covered on p49.  He even cites an example of pine being used as a main heating source on p50.
On p56 he states it is better 'to have a mixed stack of hardwoods and softwoods that can be used according to the outside temperature' ie softwoods can be burned more intensely without making a building overly hot.
You said 'nothing' whereas actually there is some info there.
Ok, you got me there. :D I should have said very little in a book 191 pages long. But The pages you mentioned, 60 & 61 dont really giver it a glowing reference does it? Kindling and Kitchen Wood, not really a hearty endorsement is it?
Aye but not all the book is about the wood - stoves, saws, stacking etc take up a huge part too.  The book loves birch (as do I, it's burning in my stove right now) but also discusses softwood as a fuel source (as kindling, 'kitchen wood' and also as a main fuel).  Indeed the dude who builds the big arty ring piles does so ordinarily out of pine or spruce, because that's what he can get (he's in Norway).
I suppose all I'm saying is that there is nothing wrong with burning softwood.  It works, and in certain circumstances can even be advantageous.  But you'll have to load the stove more often and split more wood.
3 minutes ago, Big J said:
Whether or not a book refers to burning softwood or not, it is a much better fuel for the following reasons:
  • Grows uniformly, usually with a single stem and depending on species, on quite poor ground
  • Grows more quickly than hardwoods
  • Can almost always be mechanically harvested
  • Can almost always be put through a firewood processor
  • Dries much more quickly
  • Gives little away in burning performance and tar build up is only an issue if unseasoned wood is used or the fire is over damped.
I don't know how high volume firewood suppliers manage with hardwoods. It's rare to get really good processor grade hardwood whilst softwood is a complete doddle to process.
I hate processing hardwood, unless its Birch.
Softwood is great to process too, but I dont have a Kitchen Fire so have little use for it other than Kindling. :D
Just now, woodrascal said:
No you don't if you burn dry wood in a good stove with a sensible amount of air...
The book in question specifically states that its the oil content of the Softwood and not the moisture content. I'll go with his and the Norwegian Institutes assessment over yours I think?
Mytting was on about burning large quantities of pine re having to sweep the flues more often. I guess this would be true for any wood with a very high resin content.
But in reality, apart from the colder parts of the UK perhaps, I don't reckon on people needing to sweeop their chimneys more than once a year.  Maybe twice if you burn a huge amount (of any wood).  But people will see what comes out of the flue when it's swept and be able to gauge what is often enough for their burning habits.
I was wrong to suggest there is ‘loads’ about softwood Andy.
I am prone to exaggeration of size and volume. My wife will confirm this.
I don’t want to put anyone off the book, it’s fantastic and I’d recommend it to anyone.
The big lesson it contains is that you should crack on with your supply in the spring, even if for the following winter, taking advantage of the summer heat to dry processed logs.
Re softwood - I’ve always burnt loads.
My flue is swept once a year and it’s always clean as a whistle.
I burn hardwoods as well.
I’m not suggesting that conny is as good as the beech, ash, hornbeam, cherry and birch I also burn, but I like feeding the fire in the winter, which you have to more often with soft.
I like the ‘action’ behind the glass, and the crackling and popping.
Take that you dirty macrocarpa bastard! I remember taking you down.....
It HAS to be bone dry.
After a day in the sleet I like the fire ripping, red hot, with me sat in my pants.
Then the wife comes in wearing just a towel.
The towel slips off.
There is sweat on her inner thighs.
I move my head towar
