Here’s something to look at. This chain was new only used a few times. I’ve marked it with a red arrow. Why do you think this happened .....?. Btw. It’s a oregan std 3/8 ripping chain.
If you look closely, you can see the rivit heads of the tie strap are Different to the rest. One or both rivits, as I can’t remember that well, was over tight which resulted in the tie strap fracturing.  you can guess I was happy to find it  while I was sharpening the chain. I recon if I’d done another cut it would have snapped. Edit: on the other side as well.
anyhow back to Your chain snapping.
I'm wondering if all the stresses of you using it before with the std 3/8 sprocket has weakened it and now it’s showing. I have noticed another mark in your  Pics, but cannot see the rest of the chain to see if it’s more uniform thing (ie drive sprocket damage)
i guess One way to find out  if your chains haven been weakened, is to use a brand never been used new chain.
Edited by Wonky
On the other side as well
That sounds logical. At first I thought nah, good money after bad but the lo pro does cut well so I might. I uploaded a video close up of one of the lo pros. Thanks a lot for for time
My thoughts are free,? as well is my time. I prefer chainsaw to tv and its always good to try help others.
and this leads me on. To your vid, good vid by the way.
I took some screen shots here and there. I’ve marked the bits which have similar marks on the underside of the tie straps. I don’t know for sure (maybe someone else could chime in on this) but could these marks be the weakening area from the previous 3/8 sprocket. I’ve never seen marks like this on the underside of the tie strap before.
and also there in the same place ie behind the tang..
Ratman you beat me to it ? I was typing and marking the screen shots.
Some of those links on their underside look quite worn to nearly burred on your vid, wearing close to your rivets, you defo getting enough oil?
Yes. Oil on full.
Thanks guys. I will buy a new lo pro and see
My thoughts are free,[emoji6] as well is my time. I prefer chainsaw to tv and its always good to try help others.
Ratman you beat me to it [emoji6] I was typing and marking the screen shots.
I shagged a chain up just before xmas on a 021 running with a knackered sprocket and the oil pump was weak on it too. Those straps look very similar in the way they have worn, so it just makes me think that a slight shortage of oil may be a contributing factor on the chain failures, heat mainly being the starting point of weakness setting in.
