Evening all
Have any of you down rated a 5 or 6 tonne iveco daily or sprinter tipper to 3.5 tonnes?
I know the payload would be next to nothing! I'm just interested in how difficult it is and who to contact to get it done?
Many thanks
i downrated an old dodge 50 camper from 5.6 ton to 3.5 .
i used a company called SVTECH , simple enough i just had to wiegh it then they sent out packers to fit under the bump stops, then i just got it tested and replated, this was about 15 years ago so i could be different now.
2 minutes ago, Dan said:
Thanks for the replies.
Is there a max weight allowed for the empty truck ?
As long as its under the 3.5 ton you will be fine, you are going to end up with a very small legal payload though.
Bob
Bob
Yes I'm sure it'll be next to nothing, but it's not much on a 3.5t crew cab anyway and some of the bigger weight trucks seem to go for a lot less money.
1 hour ago, Dan said:
Evening all
Many thanks
been looking at this myself so found time and courage to ring dvla and it may be easier for you than me as the truck i was looking at is 4 WD and was looking at changing taxation class as well for me theres a lot to do with forms and photos so hence why my head is up my arse at the moment,
I just looked up the kerb weight of an Iveco 35c12. 2150kg with no body on of course
the Iveco 65c18 is 2350kg according to the spec sheet.
I was surprised it's not much of a difference really.
Edited by Dan
