What about the classic 2wd tractors, grey fergie, MF135, international b275, ford 4000 and that kind of ilk? Can get plenty of decent ones for well under £5k and they are a bit of character too, also good turning circle and generally quite a bit of horsepower 35+. Downside is they don’t generally have much in the way of aux hydraulics but fine for PTO work...
Kubota b7100 hst. Mine has front pto, front lift, mid pto and it lifts 500 kgs at the rear. I have added a front weight, removed the front pto for better ground clearance and bought 4 new tyres for it since that picture was taken.
I've got a Yanmar YM1600 to mow, carry etc. round my 2 acres of paddock / orchard. It's 16-18 horsepower and doesn't struggle with a 1.1m topper mower. Does a reasonably neat cut but is not much good in tight corners. It's 2wd which is fine for me - diff lock gets it out of most sticky situations, and if it's really wet I just won't use it - don't want to cut the ground up. It's an ancient import so no roll cage etc. and it can be a bit hairy - most of my paddock is on a slope. It was fine for the first year, but have had coolant leak problems this year which I don't seem to be able to permanently fix - I just use it with a weep of coolant, which I probably shouldn't, but it keeps going! it also need front wheel bearings and some other bits and pieces.
Oh, and it sips diesel - probably uses about 0.5 litres an hour! A bit more when mowing maybe.
Cost me about 3K to include a mower and a link box if I remember right. Tempted to get a log splitter for it one day, but in retrospect I should maybe have spent a bit more and got one a bit newer!
If I had more space and more acreage I'd have gone for an old international of some sort. Compact tractors are expensive compared to bigger tractors, but I don't have space to store a bigger tractor, nor really a need for one. And they're thirstier.
I’ve got a 4WD Shibaura with low hours. Around 550.it could be for sale. It has an American topper, a post hole borer and there’s a single furrow plough too. Bad points are the Seat is needing replaced and the original tyres sidewalls are cracked but have great tread80-90%. No air loss £3000 the lot. Trailer not included!.IMG_0212.thumb.jpg.9a48676b3b00ff5d6f65e650550676b3.jpg
