Only if there's no anchor for a winch. [emoji106]
Ground stakes[emoji851]
The Kellfri I looks good value.
Just thought of a plus...the jack would be a lot quicker
9 hours ago, westphalian said:
Thinking do I really need a tree jack?
Seen people on here recommend them but they are not cheap.
Any situation that a tree jack could handle that a winch couldn’t?
Browse
They are fantastic and even the 1.6t one can shift a lot.  In an ideal world you would have both but if you had to have one then the winch is the more versatile bit of kit.  Lot more set up with a winch and a lot more kit to lug around the woods but and its a big but, if you get a tree stuck and you don't have big kit on site a winch will get the tree down.  Your tree jack wont.
I can't think of a situation where the jack has done something the winch could do.  However i've done more with the jack because of less set up.  If you're doing a lot of timber above about 18" then just having the jack is great.  Because of the slight height it applies the force at it makes work a bit easier than sticking a 20t bottle jack in the bottom.  Obviously the 20t jack is massive so you need big timber to put the dam thing in.
5 minutes ago, westphalian said:
i bought the kellfri?
That is cheap.  Almost worth just having one at that price for the one time you will really really need it.  Much cheaper than the original one.
Wot are the jacks limitations??
Could they push a tree over that would be impossible with wedges?
Have had odd big outsiders that ur trying to fell in/along te fence and ur battering away with sedges and hi lift and not getting very far
i would still use a winch, wouldn't want to be between a fence and a back leaner doing a Windy Miller impression (you have to be over 50 for that reference) with the jack
Edited by westphalian
