Hi All,
 Recently ( in the last few weeks) my saw won't start when it's hot. I've tried to "reset" the carb by starting from cold and running for 30sec on choke. Then switch off and start normally and run for 30 sec+ with no effect.
The only way round is to leave it ticking over for ages which I don't like to do.
I'm a hobbyist so the saw gets plenty of use in the winter weekends and an hour or so a day in the spring/summer /autumn and all weekend. All so far with out issue. Saw purchased 2016
Is it a fixable defect or back to the shop?
Thanks Bob
I've seen it written that you can kind of reboot the carb setting software by working the saw flat out in some big wood for about 5 minutes - really work it.
Might at least be worth a go before taking it back.
11 hours ago, john p said:
Will be the fuel solenoid I reckon, £16 part, easy to fit
Thanks....I'll have a look.
All out of stuff to cut, but I'll see if I can give it a go.
Many Thanks
Bob
Hi,
If you want to do a M-tronic reset on the MS 261 C-M, start the engine, leave it on idle for 90 seconds and then switch it off. Do not rev it during the reset process.
Hope that helps.
Paul
1 hour ago, STIHL GB said:
Hi,
Hope that helps.
Paul
Many thanks Paul
I have yet to give it a go but I will in the next couple of days.
Bob
Hi All,
Again, Thanks for this. My parts diagram doesn't show a fuel solenoid and I get no hits on any internet searches.
Can anyone supply a part number , or better a link to the service manual.
I have this one...but I don't think it deals with m-tronic.
MS261_parts.pdf
