If any of you guys haven't got one of these, then you're missing a trick! Will carry & tip over half a ton & will drag a quarter of a ton at least. For more information see the helpful friendly folks at @equip4ind  quality kit & quality service ? ps short of hiring a crane there really was no easier way of getting those rings out. Cheers Danny ? ?
Edited by inthewoods
high tip is better to save double handling getting them on the pickup.
We hire in Hinowa ones infrequenty in the building (all too small to be usefull) and they are ok and take some stick.
On 13/03/2018 at 21:04, woody paul said:
If that's you truck in the back ground in pic 4 look good access for mini loader then no picking up to do.
That picture is just the first part, you wouldn't get an avant / multione down there... A vermeer yes maybe but the ground is so uneven, with too long a log would tip over. Only just got the chipper down there! ?
These chippers will go just about anywhere ? we got the body with ours but that’s sat waiting to be modified, as the time to lift the chipper off the tracks to swop it over kills it.
I’m going to make it tow behind the chipper so it will chip and extract on tight sites
I had the body as well & was going to get another tracked peruzzo (just the dumper bit) to go hand in hand + I'd have a spare to keep the chipper moving but this is so much better.
Have you tightened up the drive belt yet?
Well the point is you’re fighting your way through a mess of fallen down trees with a couple of tiny machines to bring out.......bits of wood.
Cannot see the rationale.
