ECHO 2511 Is a STIHL OR SUGIHARA Bar and Chain best ?
arboriculturist
Just wondering what you prefer on your ECHO 2511  climbing saw:
The STIHL 10" Bar and STIHL  1/4" .043 chain    OR THE     10″ Sugihara bar with Sugihara 1/4 .043 chain ?
The saw came with almost a carving bar supplied and the standard 3/8 chain, which is aggressive to say the least - perfect for dismantling though.
Time for a 2nd saw while offers are still about.
Edited by arboriculturist
I'm running the sugihara bar and chain. I'm not 100% convinced in all honesty, the chains aren't perfectly sharp from new so need a little touch up, first chain I had snapped and the chain is over £20. If was buying today i'd get the stihl setup and I may switch when the bar wears out
1 hour ago, MattyF said:
Stihl Set up is working well, could not get on with the echo bar after using 150’s ... target pruning is spot on again now we made a swap.
I take your point as we have 150's also and the 3/8 is too aggressive for target pruning.
Just another link in the Stihl 150 chain and I can't recall the mod required on the Stil bar to allow it to fit the 2511 - additional hole drilled I recall from the Tiny Echo historic thread?
