562 sprocket choice??
TheHungrySquirrel
Standard it should be a large spline. 560XP is on the smaller spline. You could get an 8tooth sprocket which will just fit without adding a link to the chain and with enough adjustment left on the side cover.
Can’t really help with your 404 idea, sounds plausible though if you can get a bar to suit which I’m sure there will be.
