  On 05/02/2018 at 19:23, Justme said:
Expand
I think this is the same arrangement as a Dutch firm I looked at for my old job where we had a carlton 7018 to move around. I liked it because the coupling could be covered to make the grafter a flatbed when not towing. At the time the coupling was not homologated for UK.
  On 05/02/2018 at 19:44, Justme said:
Any weight that is transferred onto the vehicle is NOT trailer weight.
If stopped they do not uncouple you. They weigh each axle.
So the 100kg will be on the rear vehicle axle not the trailer axle.
Expand
Thanks for that.
Thanks for that.
Expand
I would guess that as the Eu regs approve it where it is made it has to be accepted here.
  On 05/02/2018 at 19:54, openspaceman said:
That's what I thought but 'phoned the Dutch company and they said it would need to go through some sort of type approval
Expand
Perhaps they now get IVA testing done, but thats for trailers not fixings.
In the Netherlands the rules are not the same.
The way the gtw of  dedicated B+E artic is determined involves multiplying the maximum axle load of the rear axle, so what they do is stick a jeep dana axle under an iveco getting combination with a train weight of up to 16t...
If the vehicle has a 3500kg MAM & the trailer is plated to 3500kg then a post 19-01-2013 BE is ok.
The vehicle could weigh 1900kg.
The "load" from the trailer be 1500kg.
The trailer axles weight be 3500kg but with a disconnected weight of 5000kg.
Expand
nope.
rear axle limit on 7.2 daily is 6 tons. downplated its a 3.5ton vehicle.
Again you confuse the two.
you cannot put 6 ton on the downplated solo tug. you CAN put 5 ton on the rear axle towing a trailer whilst observing the plated train weight as there is no trailer weight limit on B+E.
B+E is allways a better option than C1+E if you have an old licence.
The only hassle is obtaining the right downplated tug for your application, but there are many out there from 4 tons upto 12 tons payload. All without the hassle of C1+E.
Donk,
MAM vehicle OR trailer
GTW or GCW vehicle, vehicles load, trailer and trailers load all combined.
the typical landrover (not all) has a MAM of 3,5t and GTW of 7t
the LR on its own cannot weigh 7t
from the link you provided:
  On 06/02/2018 at 05:39, donnk said:
nope.
Expand
Not sure why you think what I put is wrong as it does not contradict what you have put.
Edit to add.
The weight applied to the rear axle must keep the total weigh of the tug within it's Mam. In your case it won't.
Edited by Justme
  On 06/02/2018 at 05:45, donnk said:
err yes it does.
And according to the Gov they are the same.
I think you are splitting hairs.
https://www.gov.uk/vehicle-weights-explained
Expand
As posted above MAM is not GTW which is now called GCW.
Mam is just the max the vehicle and load can weigh.
GCW is the max the combined vehicle and trailer can weigh.
MAM Maximum Authorised Mass
GTW Gross Train Weight
GCW Gross Combined Weight.
Edited by Justme
Read more
