37 minutes ago, Matthew Storrs said:
I think the oil will be as clean as a whistle- not really much chance for dirt ingress as. Quite looking forwards to doing this now!
It won't be a job anymore. Hose in one end, hose out t'other, attach cable tie.
I'd spend the time saved drinking coffee, probably slope of for a fag at the same time. Other folk are more productive.
assuming the tank has a drain plug ,if it is in a inconvenient place you can get a hose made up with a blanking plug.
Replace the drain plug with the hose and your next oil change is easy
Why don’t you crack a hose off the machine and let the digger pump it’s own oil out into empty drums? If it holds 75 litres pump out 65 and then faff about getting the rest out however you see fit. You can’t spill as much then.
  • 1 month later...
  • 6 years later...
I know this is an old topic but the original poster's story reminded me of the same problem back in the early 90s... and now I am facing a similar issue with a smaller machine -- only 12litres of oil.  Am looking for an extraction pump because there is no way I am going to get 3+ gallonsof transmission (hydraulic) oil via the drain plug and don't have a lift for this 1000kg machine.
Edited by JKahan
This works well From Sealey, I've drained 2 hydraulic tanks and a few fuel tanks with it.
