I have a bit of a dilemma as far as the best splitter for my needs goes - the yard that I rent is not great, security - wise, and since PTO driven is out as we can't have a tractor there, we are left with electric powered which would still require an adequate generator (no mains power there), or one of the manually operated options. I like the idea of using one of the latter, but has anyone used one that is actually any cop and with sensible pressure, and can split fairly quickly? I'm not a major firewood producer and really most of it is arb waste; but currently everything is processed with saw and axe, which is getting a bit tiresome. Any recommendations for a decent foot powered splitter
34 minutes ago, Acer Forestry said:
A guy I know whom I spoke to yesterday, running a Posch PTO splitter suggested that his could be run off a Vanguard unit or similar, if correctly set up; is that the kind of arrangement you mean?
Hi Acer,    where ya based as i may be selling my petrol powered hydraulic splitter?
Kent. We do get down to Devon in the summer / autumn but not very likely at present, as flat out with work. But do give me a buzz please, Phil 07808 738097
...It's only a hydraulic pump on a lil petrol engine ( and a oil tank )  , most engineering firms will knock you one up - then any hydraulic ram driven splitter will do , K
I run one of the 12 ton Rock splitters, it's not perfect but it would be a step up from doing it by hand. One advantage for you could be the size / weight as it is light enough to get in the back of a pickup or van so you could bring it home rather than storing it at your yard.
With one loading and one working the ram we can do a cube in about 45 minutes from arb waste, not lightning fast but we tend to split the nice stuff with an axe and sling the tough stuff in a pile for the splitter. A tip I got from one of the guys on here was to put it on a set of car ramps to lift it up to a more friendly height.
Depends how much you are planning on doing as it could be a could be too small for your requirements.
