Sign in to follow this
jonathan hall
DIY 'easy rails' for the alsakan mill?
ive been using the alaskan mill for about 3 or 4 years now and have 3 sets of rails but... the vibration on the wee screws that set your pitch, enlarge the hole that they sit in and this causes the rail screws to unthread whilst your cutting your top board.
ive thought of a few different designs, but was wondering if anyone had made their own or had thoughts on how to design better one?
(not wanting to strap on old ladders! )
Share this post
Link to post
I have never used easy rails, we have always used a ladder, works fine and never had any problems, you just screw it to the timber through the rungs.
drill pilot hole thru runs and use long self tapping screws?
we had thought of that, do you have to just invest in good, sturdy ladder to avoid sag ( i use two 88's and is quite heavy) i was just worried that i was gonna banjo a good ladder!
Share this post
Link to post
Thats it Jonathan, just drill the holes through the rungs, make them a little larger than the screws you are going to use, we have found over the years you can use any type of ladder be it a good one or a poor one, if its attached to the log properly your are only using it as a guide for the first cut, hope this helps.
Share this post
Link to post
Just set the small scaffold rails up over the log, no need to bolt it to it as long as the log is chocked properly
The problem with doing that is it takes a lot longer to set up, just pop the ladder on and away you go, saving time wich makes the day more productive!!
Share this post
Link to post
:dito::thumbup:
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
