  • Replies 32
i need sycamore to be milled within a couple of weeks of it being felled.
if your rings are 15" along the grain by whatever diameter the tree was and you can cut them up for me then i may be interested...
i could use that for 6" pins in theory?
Sadly they're a bit shorter than 15" otherwise I couldn't lift them!  Good luck.
I've got a couple of 14ft trunk sections from same tree in the yard. Felled on 4th Sept.
Some rot at the base, not sure how far up it goes. I'll have a look if you think it will be any good. Was in a garden.
