Our 3.5 ton Iveco's might be able to tow 3.5 tom legally but they don't like it much. The Izusu is a much better truck in my experience..
The landrover can too, but it doesn't like stopping...
what engines in it .2.3 is a bit lame ,
  • Replies 23
Most trucks will tow 3.5 tonne some do it legally, Not many will stop with that weight behind most pickup sacrifice load weight for train weight. With overun brakes a recipe for disaster. Your tow truck needs to weigh a similar amount to the trailer if not more this is basic physics
This leads you to Landrover 130(maybe)or iveco, transit and Toyota
What others have I missed
After putting the 3rd or 4th clutch in one of our 3.5ton ivecos we have been told that there are 2 variants. Unfortunately you can't just put a heavy duty clutch in the standard..? That explains our difference in experience..
Not sure about that, but I was told that they're dual mass flywheels. I was warned that when the clutch goes it usually takes the flywheel with it and on the 2.3l you can replace with a solid flywheel conversion but not the 3l as the extra torque is too much for the drivetrain, so has to be replaced with the very expensive DMF.
Regards,
Steve.
