560xp oil tank gasket
Dilz
A 560xp stop oiling. When i got it I emptied the oil tank - found that the metal oil filter had come off the pipe - which is probably why the pump got clogged and the saw stopped oiling.
I then noticed some pieces of black stuff that i assume are from the gasket - its the only thing i can think that it is to get in there like that as the pieces where not so small - There are no oil leaks and the saw runs so I guess its from some over lap of the gasket hanging into the tank that has some how perished? maybe from the oil over heating when its been trapped in the tank? Or is it likely something else? (i.e do i need to strip the saw and replace the tank gasket)
