Was thinking of purchasing a 576xp with a 24" bar, should be able tackle most take downs with this or should I just go for the 395xp. Just feel that the big saw comes rarely enough to warrant the purchase at this point...
  • Replies 24
I would go for a 390 over a 576 . They weigh almost the dsame but the 390 makes more power . But if it was between the 390 and the 395 it would be 395 all day long .
I have a 576 and a 395. My verdict is...................buy both!
A really sharp 576 is good enough for most everything.
S'funny you should ask this because I went to the pick up today to cut a pretty big oak butt off an uprooted stump (3ft or so) I got out the 395, tightened the chain, and then my eye caught the 576 sitting there and so I used that, it was lully!
Having worked at a firm with all the gear it just seemed like the 880-661s just sat in the lock up mostly and the 460s went out. When spending nearly a grand I want it to be versatile
Sent from my iPhone using Arbtalkc
Big saws, when you need 'em.....you need 'em.
Something like an 088 you'll only buy once in your professional life. I don't use mine often, maybe 8 times a year, but I'm glad I've got it.
It's tricky to make a decision, I willl say that whenever I've gone for as much power as I can afford, be it vehicles, saws, tractors whatever, I've never regretted it.
576 is a cracker though!
I have been using a 576 for a few weeks, it's nice, also have 441 similar to the husqvarna in terms of capability just different in terms of where the power is, have to say i like the 660, bit heavier but a nice torquey power del. is steady and it seems unstoppable, not as nimble as the others, but guess u cannot have it all
Get the 576 now and borrow a larger saw when you need it until you can afford your own.. You can do alot with a 24inch bar
Sent from my SM-G930F using Arbtalk mobile app
For sure, however affordability isn't really the issue. I could go and get a 3120xp it's just the average of takedowns rarely require enormous bars so a smaller saw would just be of more use perhaps....
Sent from my iPad using Arbtalk
True . I sold my 3120 on a 50" canon bar as it got used once in a blue moon .
