Compression testing with a decompression button
Ricko
I know a compression test on a two stroke can reveal only limited info but I assume it's a starting point with regard to piston/ring/cylinder condition.
I have a few Makita DPC 6400 lying round (forgive me, I know they're not chainsaws!).
Do I press the blue button IN or pull it OUT to attempt a compression test?
I'm going to attempt to build a good one from the pile and want to select a goodish one to start with.
Comments much appreciated.
The button should be out for full pressure, throttle half open pull it a few times to reach max pressure.
Try that on a bigger saw & all you will do is damage it & yourself. We laugh @ work & call it the tart start, but why ruin a machine & your elbows?
None of my smaller saws have one (my 50cc dollies might? dunno tbh) but the husky 372, ms660 (with big bore P+C!) and ms880 all start better without the decomp?
I've never used them, never broken a starter (had a cord snap once or twice on aging saws) never had any elbow issues?
Starting a saw isn't really something you do that often, and the bigger the saw, the longer the cuts and thus less starting?
Maybe when I'm really old I'll regret this, but I think not.
It is only in the last couple of years I have began to think this way & only for bigger saws - 390 660 084 etc must be getting softer as I get older :)
