Slight thread resurrection. Any decent quality aftermarket cylinders available now, or does anyone have a decent 50cc cylinder available?
I buggered mine up today trying to clean up aluminum transfer, I let the acid get onto the edge of the exhaust port and now the nicasil coating is all knackered at that point. Stupid me.
1 hour ago, spudulike said:
Not a good time to get any parts. Supply chains are in a bit of a state. If the saw is going to go out and earn your living, go OEM!
Yeah, that is the problem, it isn't a saw that I would make money with, its already a loss making exercise after I bought the other bits required to rebuild, which I now don't need.
I'll keep them in stock until I rebuild another 346 I have, but it is a bit of a kick in the balls.
hi again..i went with this kit and it has been fine...
https://chainsawpartsonline.co.uk/husqvarna-chainsaw-cylinder-piston-kit-44/
after i broke it in i tuned it to 12,500rpm and as above it's been fine no problems...ps  i also fitted caber rings.
Found a new oem cylinder and piston on Ebay from the US for £110. Figured it was worth a go. Part no. 544 14 29 07 which shows as a 50cc with no decomp and the photo shows the decomp hole hasn't been machined. Hopefully it'll be OK. Or I've thrown more money away!
Just put a bung in it if it has? Or do your covers not allow clearance?
It is the new cylinder that doesn't have the decomp plug hole.
