I like to keep my mind open to this kind of thing, I went through a water pipe in a field, Was sorting it out myself when a bloke from South west water turned up, apparently the pipe also fed neighbours horse trough so they called them.
Anyway he looked at the hole where I can gone through the pipe and 3 meters away preceeded to walk over the area with his dowsing rods- "oh there it is" he says and I watched his rods move together. I thought is was quite impressive at the time, but it only twigged when i was going home that i had capped off the water pipe where I had broke it only 2 days earlier- there would have been no water at all in the pipe he 'located'
Anyone do this sort of thing- I have tried it in the past with very little results but perhaps I wasn't in the right mindset!
  • Replies 31
My brother can do it.
He doesn't believe in dowsing, doesn't like it, and doesn't understand it, but he can do it.
Just a pair of bent wires and he'll find waterpipes, drainpipes etc
Out of interest rover, can you do it? Or tried it?
I have tried, and failed
Same as. My sister couldn't wear a wristwatch (to much electricity in her body) or something like that, anyway the watch would stop working. Probably the same thing when it comes to dowsing.
Hmm, interesting must have a crack, put those wire coat hangers to good use...
Strange how it works for some
N
