Hydraulic fitting torque settings
Paul in the woods
This is probably a daft question but does anyone tighten their hydraulic fittings to a required torque or just 'tight enough'?
I ask because I cannot get any details from the makers of the walking excavator I bought. I obviously don't want to spill oil about the place but I don't wish to damage the fittings.
The fittings are steel coloured, with an approx 30° face, and probably M14 size (OD of the male thread is about 14mm). Female connector at the end of a hose and male on the cylinders.
Can anyone suggest a sensible torque setting?
if your tightening a taper face seal, run the nut up till the faces meet , then finger tight, then half to one flat more with a spanner, any more and you risk damaging the sealing faces, this applies to bsp, jic, metric, japanese metric and komatso tapered. orfs, sae3000 and sae 6000, seal on the o ring and are a different story
Most hydraulic fittings are on pipes which kind of precludes the use of torque measuring, most of which is done on socketed implements
Crows foot socket on a torque wrench but I understand your point.
I guessed hardly anyone would torque them but not having used hydraulic fittings when I googled tightening I came up with loads of comments about torquing them.
I'll tighten them as suggested, finger tight and then a nip with a spanner. Thanks everyone.
as said in this reply then just check none have backed off after a few hours use
