PINS inspectors often much more reasonable and often take a sensible approach. Some TO's are ..overly protective IMO
I've done dozens of fast track appeals and a few hearings when working as a TO and only ever been overruled once by the PIN inspector. I knew I would as well and only refused the application on someone higher ups instruction. I always think if the PINS inspector is going to give it then why bother refusing, its a waste of everyone's time.
I take your point about some TOs though but they are not all bad.
  • Replies 21
I did say some...
TO's are all different and standards vary massively. When quoting works my advice varies from borough to borough... I know in some boroughs they basically have a blanket ban on reductions.
So far I have had had the PIN overrule or come up with middle ground more times then not. But it's such a ball ache (takes months) appealing, and most clients are not keen to pay for it, when the outcome is unknown.
I have recently decided to contest a few that I believe unreasonable at no additional cost to the client in an attempt to re-educate the overly protective TO's.
I did say some...
I have recently decided to contest a few that I believe unreasonable at no additional cost to the client in an attempt to re-educate the overly protective TO's.[/QUOTE]
Whilst it can be a hassle (time & effort the customer doesn't want to incur) as you say Ben, setting a precedent and proving your point could pay longer term dividends in reducing the potential blocks to subsequent sensible / reasonable / appropriate applications.
If you're sufficiently confident of a positive outcome, and believe there to have been unreasonable behaviour resulting in the need to appeal, it could be that costs might be applicable to recover expenditure.
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/7720/costawardsinplanningappeals.pdf
https://www.gov.uk/guidance/appeals (this link is more current)
It could be a double edged sword where you end up getting costs awarded against you but the common thread seems to be frustration with decisions that appear to be poorly considered so if the case presented for appeal was carefully chosen, and attempts to resolve had failed.....
Decisions on applications / notifications might be taken with a bit more care and attention to detail if the prospect of appeal and costs was the consequence of bad decisions.
I did say some...
Very much my way of thinking, but much more eloquently written than I would have put.
One addition, now that I'm a bit older, I never take a refusal personally and accept that it's a differing opinion- even when it's just wrong. I live a more stress free life, mostly, and think whatever I need to do next might, just might, make a small change that will be beneficial in the long run.
There's no right of appeal against the making of a TPO.
...except a Judicial Review at the High Court but this would need to relate to a procedural failing in the way the order was administered.
If you go fast track you will get an arb consultant, if you go hearing you will get a planning inspector.
Not for much longer. As government favours flexible generalists to specialists who only feel comfortable dealing with their specialist subject, I am led to believe that the arb consultants are being shown the door (1st March?) and you will get a planning inspector (having gone through some sort of short-term training) for all future appeals.
I recently had a hearing with a planning inspector and I was struck by his arboricultural insight......of course I was as his decision was in my client's favour! I just wonder whether they all will be!
Jon
True. What limited experience and knowledge I have of these things is that it comes down to a simple quetion of whether the tree is important for the amenity of the area. As long as the Council has not decided it is important on an unreasonable basis, there seems to be a reluctance of courts to interfere in Councils' discretion. A Review in theory is possible if the Council failed to consider the importance of the tree at all. And a succesful Review might merely result in the Council reaching the same decision later without the procedural mistakes.
Therefore 6+8+27 so it is the best part of a year before you get a decision..
Add on time between the 6 and the 27. PINS won't touch an appeal against a TPO decision unless the tpo has been confirmed. This could be any time within the 6 months after having been served. Bung your 27 weeks at the far end of the future.
The Tpo placed is for the LA to control work on an important tree.An application for necessary arboricultural work on the tree may well be approved; as conditioned.
Jon
I heard a while ago that the one of the PINS inspectors was attending the Tech Cert sessions with Treelife with a view to getting an arb qualification. Good idea I would think but it made me wonder why the arbs wouldn't do the same in getting a planning qualification to better position themselves.
I was told by one of the inspectors that the reason the arbs don't do hearings is that they don't have a formal planning qualification which is a pre-requisite. Seems like a no brainer to me.
Bit late now I suppose.
