  • Replies 23
Yer, I think yer warranty won't stand as it's a mineral oil.
Were is that " bashing your head against a wall " icon then John ? :biggrin:
There was a test with 4 new engines...1 filled with cheap 2 stroke/1 with hp standard/1 with hp super/1 with hp ultra...the engines were all run for 50 hours...when the engines were stripped down the cheap 2 stroke as expected had caused damage the piston cylinder etc/the hp standard funnily enough had the same result/the hp super showed wear bit everything was ok/the hp ultra showed absolutely no wear at all...hope this helps
Sent from my SM-G935F using Arbtalk mobile app
Any links to said test?
You can mix whatever colours you like and get yellow. I tell thee!....
:thumbup: cheers, Steve
[ATTACH]215792[/ATTACH]
I would lay off those shrooms......not good for you hippy types:001_tongue:
