Evening all,
So I have one of these.
And whilst its ok as a felling lever using for anything else is pointless. The black hook just does not hold. What is wrong? What, if anything can, I do to fix/improve it. Or worst case what else should I buy?
Thanks
Chris
Sent from my iPad using Tapatalk Pro
  • Replies 52
Also, you really need to move both hands as far back as possible, you are strangling it (thats how my joiner dad used to describe my use of a hammer as a child, holding it too near the head)
If you want to roll big logs a proper cant hook is better. Since I got the bigger felling bar, 4' like Skyhuck's, I very rarely use the wee one. I find you need to give the hook a good kick to get it to bite if you're using it as a cant hook, or even a couple of taps with the hammer/axe if it really won't bite. Bigger bar gives more leverage for felling too. Obviously this is ground based, up the tree wee bar is lighter and easier to handle.
