I've had a look at the diagram and from what you describe it looks like the 3cc section of the pump is bypassing the valve limits it to 120 bar when its activated bringing in both pumps to increase the flow and 170 bar when its not so you definitely need to start by putting a gauge on it
  • Replies 61
Its a tandem pump, but one side is running the conveyor, or so I thought.
there is a test port or two, so will get a tester and see.
I don't quite understand that but think you are describing a power or torque limiting protection.
Both pumps run the motors when the going is easy but if the load gets high one pump bypasses to tank whilst the other pump is able to run at higher pressure but only its flow. Power being flow times pressure.
Now I am confused! The tandem pumo I have has two pipes coming out the side, a smaller one near the front, and a larger one at the back. The smaller one is connected to the conveyor side, which is operated by a lever, bolted on to a central block that has a couple of pressure valves in it, and i presume the solenoid for the higher speed, on the other side is the two valves for the tracks.
are you saying that in high speed, it takes oil from both outlets of the pump, and low speed only one outlet?
The hydraulics are obviously modified on the crusher machine you have, but on the standard TCP HT500 dumper, the small pump does low speed, and both pumps combined do high speed
"1.3 Hydraulics
Refer to the Hydraulic Schematic drawing in Section
7.22 Carrier Hydraulics Mk4 –2006 Drg 1599.
The diesel engine drives a hydraulic pump coupled
to its shaft. This pump provides two outputs:
• a 3 cc per rev, low flow, high pressure output for
low speed and general use and
• an 8 cc boost output.
These are combined to provide an 11 cc/rev high
flow, high pressure boost drive for the high speed
track drive."
Yes when travelling but presumably the conveyor is not used when travelling?
