How do small petrol engines stop?
mikecotterill
Mmm ok well it's going on an rg25 grinder, there's only four wires on the ignition switch one to the power on the starter one for the power to the starter solenoid one to a wire in the carb and one that I'm unsure where it goes, will have to get out the multi meter and have a good poke, cheers guys
I found a wiring diagram for a Kohler a while back if I remember there is a feed to the starter a live from the battery an earth and a wire from the coil in the off position the earth is linked to ground in the run position there is nothing connected and in the start position the starter is linked to the battery
