Hi all,I was wondering if any of you climbers put a back up bridge on your harness.Ive seen more and more climbers do it.I have a treemotion and it would be easy to fit.
It would be removed for loler and only a back up incase the bridge got cut or badly nicked.
Thoughts..
Thank you
  • Replies 103
Thoughts..
Thank you
:confused1:Why???
A second bridge can be handy, I've seen guys use them for carrying a heavy saw as whilst top anchored it will be supported by your climbing line.
As a back up I fail to see the need.
I would not be concerned about loler either as it's not the primary life support it should be considered as an accessory attachment point.
Why bother at all, where do you stop backing up. If they dont like a treemotion bridge buy another harness
Did i say i didnt like the standard bridge..? No...so dont put words in my mouth please.As i stated above its a secondary back up bridge as in running 2 bridges incase the primary gets nicked or compromised.
I did not imply you did not like the standard bridge, I said they. So I am not putting words in your mouth.
(Its friday night, and the beers are evident!) I like the idea. I have a tree motion as well, and the dyneema bridge is rugged as hell, but will easily be cut by a blade or chain, especially if its under tension - I speak from experience cutting my 250 euro dyneema winch rope - the saw went through it like butter. Very very strong in tension, stronger than steel even, but offers no resistance to a bladed article.
What about backing up with a thin plastic sheathed wire rope? That should stop a saw, maybe not at full revs, but I reckon it would withstand a nick.
Its saturday mate but yeah ive had a few hehe.
I like the idea of a wire core or similar...could be into something there
