Difference between the jensen a530 and the 750 contractor
Hi there,
Just wondering on the differences between the jensen a530 and the 750 contractor?2010-2012
Is the flywheel and blades the same? Is it just a smaller engine 3cyl turbo.
Are they up to the job?
Cheers
I don't really know matey I run (batter)the little 518 and I know when it's worn out I'll buy a Jensen again. You'll have to look at the technical sheets for both but whichever you go for it won't be bad
Ive a full phat jensen a530t and was considering changing that or getting a road tow for the domestics to save on towing weight around etc. Happened to spot on e of these that looks a genuine little chipper
I've got a 750 contractor, great little chipper. Had to weld hopper by rollers a few times, They must use thinner metal on this, fuel tank smaller, spare wheel not attached and engine is different that I know of.
Blades are the same so assume flywheel is same.
the 750 has the fold down hopper, not sure if your 530t has the older fixed hopper?? we have both styles at work and the fold down one is way way better.
carl
