  • Replies 130
Hey, never use chains when feeding a chipper - a polyprop strop chips easily enough, a high tensile steel chain doesent....
Good point,and cheaper than a sling.
Actually, it was all I could find at the time. It was an emergency Job, 3 BIG leylandii blown onto the road. My grab truck was in the workshop having its brakes done, so I took the flatbed. It is SO much easier handleing stuff with the grapple and top seat controls.
The air filter on the BC1000 I used to work with was on the bottom side of the engine.You could take the end off the air filter housing without opening the bonnett¨.
Sorry. I get it now. That is how mine is too. When I said `site clearance`, I meant only if you can drive it onto firm ground - and not over brambles, saplings,tree stumps etc. I couldn`t do that. Clearly your `Mog / Farmi combo is better suited for rough terrain.:icon14:
My set up is more suited to ponsing about in the suburbs and metropolis.
But you got the job done,often think the ability to improvise is the mark of the true pro:icon14:
