Light bars
Ianwheeler28
I prefer these WOW - 20 Inch 126W CREE LED Spot Flood Combo Driving Work Light Bar ATV UTE Boat | eBay
Simply because you can slide the mounting brackets to wherever suits you. The ones pictured in the op have fixed mounting points that may not suit your purpose.
Other than that, go for it, they are pretty amazing as far as light output goes. Just make sure you mount them where thay are not shining on your vehicle, they are seriously bright and the glare can be a bit much.
Ive just got the 22" version of this from amazon. i am very impressed with the look of it. seams solid and the sliding mounts are really easy to install. i'm impressed with the light it gives off, much better than the ring halogens i had befor. its a very bright white light.
