I been thinking about this, but decided to upgrade next year to a bigger machine.
Try a different wheel you may be surprised, those Multi-tips whilst they have there merits are not great.
  • Replies 40
I was looking today but could not find a supplier
Try Saturn Machine knives speak to Nick or Martin Chignall at StumpBusters both supply Rhino Wheels and Rhino teeth, we had a wheel sent to us on a 30 day no obligation trial (well we had to pay for the teeth!)
The Rhino wheel is a small improvement on a P28 noticeably better but not a huge improvement with only 4 pockets the teeth last a long time.
On our Carlton 7015 with multi-tip wheel using Rhino teeth the difference was huge! almost twice as fast as multi-tips and went a full 2 days grinding before a change where as multi-tips we change the leaders every half a day of grinding. Much smoother to so hopefully less pillow block bearing going which are a yearly replacement for us which are pricey items to replace.
We will be demoing the Rhino wheel very soon in the Carlton which has 8 pockets.
Thank you
My advice would be to get the biggest Bandit that you can carry on your truck and a pedestrian grinder.
Then you'll have everything covered.
But what do I know. Lol!
I'd hold fire for a bit could be something in the pipeline from someone else that may be worth a consideration, or get a Bandit just make sure you get it from Dean and only Dean and never deal with anyone else but Dean.
We have a large stump grinder that is used for 95% of stumps and the P28 for narrow access only.
Big bandit, yes my thoughts been down that road. But also been down the Carlton hurricane road. But I need to actually see it might be very much to big.
Jesus the Hurricane is a completely different animal that doesn't belong in the UK! :biggrin: has something like a 2m 360 degree sweep
We run a Carlton 7015 and it is a beast that does a prodigious amount of work, but they need a lot of TLC and a good wheel the multi-tip is harsh we chew through pillow block bearings and shredded a belt a while back and these are expensive items.
The hydraulic Bandits are something we are considering in the next few years.
Really? I think there is only one in the UK and you need a HGV to put it on.
It would do a months worth of stumps with the predator in a morning.
