Aluminium carabiners ok for rigging?
onetruth
I keep the 2 separate unless I'm in a hurry and it's a little bit I'm rigging but if it's a hell of a lump I just use a killick hitch and bypass the karabiner completely.
I would guess rules and regs would advice you to only use steel for rigging and it an ally karabiner is put under huge stress in rigging then gets mixed up with climbing gear there could potentially be a major problem.
Actually rules and regs advise against using carabiners for rigging terminations altogether.
In the same way the DVLA advise against scratching your balls while driving.
I personally like the weight of steel biners, I even have them on my flipline's cause I find it easier to flip them round the tree..
I've been on sites where aluminium has been used for rigging and unless it's really lightweight stuff it makes me nervous..
If you do decide to use aluminium I'd say make sure you inspect it all the time and avoid side loading.
