Any idea what happened here?
Island Lescure
Doesn't look like lightening to me, as lightening always has a slight spiral effect to it - in your images this looks like it is formed as a straight vertical?
It puts me more in mind of a 'blunt-nosed rib' where lateral or swaying forces have caused the stem to separate along a weak axis - but not to the full extent of going right through to the other side.
See P25 of this: http://www.forestry.gov.uk/pdf/fcpg13.pdf/$file/fcpg13.pdf
Thanks for the replies.
I thought frost cracks are a myth?
Its not a tall tree and the crown is fine bar a partially failed branch probably from wind or snow.
I find it strange that it has managed to occlude and manage the higher region but not at all the lower.
I will have to prod and hammer the bottom portion to see if there is decay as I am happy with the top portion but not the bottom.
